General Panda Parts Request
Another Parts request, as you are awake(!)
The front brake caliper splash(?) plate. Mighty thin when new, I suspect. Mine are both metal lace work and I can't find anything like on UK ebay, or elsewhere.
Ta
Just made. 2 out of 1mm zinctec sheet took about 1 .1/2 hours 3 Sisleys and a 'HOLE' lot of TLC
https://www.fiatforum.com/showthread.php?t=444097
Used the original as a Template. Then an old disc to form it over. Cut out for the carrier last yes it's on the rear axel but same methodology
mighty thin and mighty hard to find new...
still looking for you
Yeah, absolutely. I've seen your thread and you are an absolute monster for this stuff, mate. If I am stuck on a desert island with nothing but metal and metalworking equipment to hand, I want you there as well :D :worship:
I was going to make a couple if I can't find any nos...trouble is I'm a chippy, so they'll be carved from elm...sigh...
Seriously, though, if nothing appears before I fit the new brake pipes, I'll be having a go at fabricating something... Given my skill set rests in boatbuilding, there is also the possibility of using the steel ones as a mould to make them out of glassfibre... hmm.
But thanks for the tip, mate.
Chris
I'll have one for each side. You want me to go through you or direct?
Chris
Going to ask the shop if both side are available
You can go direct... if problem with the order let me know
I'm going to ask if the ship worldwide as well. Otherwise will order it and then ship to you if that's ok
[emoji108]
lukmek, Thanks for looking, however those are the plastic inner arch guards, I am after the actual steel wheel arch panel. Like the one Sjvarley linked to, however that is a mk1, I need a mk2.
Ok
Will try to find the steel arch... quite difficult imo
What your panda year of production?
Its 1987, I think it will have to be a full rear quarter panel, ideally I would like a genuine Fiat one or one made by Rhibo. I'm fairly certain Rhibo are still making Panda panels so I don't think it will be too difficult?
Is this part?
OMFG; you beauty! Again, I'll have one for each side. Again, let me know if you need it to be through you, or you prefer me going direct.
Mate, you are a star.:worship:
Chris
Gimme a list of all the parts you want and I see if I can get a discount on shipping first!
Some shop won't send worldwide I can ask them to send the order to my address in Rome or London and then forward it to you
