Technical panda 4x4 LHD to RHD conversion
i reckon you could get that panel out but Iam not sure what would make it worth your while. it would be a lot of work its hard to count the welds without digging out the sealer lots of duble thickness and reinforcement. if you were doing a lhd- rhd then you would have a big job to do the dash panel as well. I will just cut some new holes and patch the old ones.
i have been adjusting my bulkhead cut some holes. i realized that the mounting points for the steering rack are not symmetrical. So i cut of the saddles, bolted them on to my lhd rack. Got the rack in a good positon tacked the mouts in position. removed the rack and welded them up. heres the pictures.
there is a rusty bit under the battery i will cut that part out of lipstick and weld it in, i may be able to move over some steering column mounts and heater cut outs in the same job. iam not sure if its worth the hassle yet.
got back at the panda after a bit of break. replaced the dreaded prop-shaft support bearing put in fuel tank which wasn't original and was a bit different but will work far me as i am gona use a carb. fitted a new fuel gauge sender which was a new land rover sender i found in my workshop (confusing as i have never owned a land rover) cut a hole bent the float and jammed it in with self tapers and epoxy putty maybe not in the best location as it it is a bit tight to the floor. not sure how it will get on with the panda gauge, time will tell and at worst i will end up with a functioning warning light. all so slapped a bit of paint (Massey Ferguson red) on the bulkhead and made a blanking plate for the left hand side for the servo to bolt to. and fitted me steering rack struts control arms and new ball joint boots
I see you have swopped out the different diameter steering clamp locator I looked at this too for the same swop l/r h d my plan would be to make a smaller diameter packer from a spare top clamp and place to the rear of the larger diameter the smaller clamp could then cutout diameter only with slits in the housing then clamp up pushing the curvature back to the new diameter remove then weld up Less work I think . for the pedal box r h d marked out and cut the whole profile then reflange the edge
Try rotating the steering rack that should increase the gap as the U.j in not central where it enters the. Footwell
i have been painting it reminds me that i don't relay enjoy painting. i was looking at at a tin of pint the other day it was labeled anti corrosion paint i wondered why any one would want any other type of paint.
the process i have been using is this.
angle grinder with wire brush to remove rust pant and filer in afflicted areas only.
sand blaster to get in crevices and really persecute any remaining rust.
2 pack epoxy primer applied with brush (hope it works as it was expensive when you ad the price of hardener and thiner)
filler sealer and high build primer where required.
more sanding and filing.
even more sanding and filling.
prep with gray scotchbrite and wipe down with standard thinners.
several coats of 2 pack acrylic single stage paint (sprint) the shop called it "the cheap paint" but was expensive again as i had to buy different hardener and thinner. all so need decent respirator.
stand back and realize i didnt do enough sanding and filling.
i have leairnt a lot as this is the first time i have painted an entire car, but i think if i were to start again i would go for a top coat of mat black applied with a 4 inch brush as it would hide the brush stokes of the epoxy primer.
