General Panda 169 Rims And tyre questions? with dimensions
ıstanbul
Hello again;
My car currently has a set of 13" steel wheels.
Aesthetically, they look quite beautiful and sturdy.
The previous owner installed a tire that was not the original factory size. (175/80/13)
The tires are 2021 tires. They are in good condition.
I'm very happy with the roadholding now.
The tire he installed added about 1 inch of height to the vehicle.
However, I have a few questions in my mind.
What are the advantages and disadvantages of having a larger tire size than the original size? This question applies to panda.
I think the front set is too heavy due to the Steel Rim.
I'm undecided whether I should use aluminum or steel rims.
I'm thinking of switching to 14" or 15" aluminum rims.
If I come across a second-hand, affordable product, I'll probably replace it.
What are your ideas? I don't want to waste money
fiat-panda-2-jpg.432118
fiat-panda-4-jpg.432119
I disassembled the part. A friend of mine has a repair shop for both shock absorber mounts. It will also help with hub and bearing replacement. He has suitable machines.
It looks really simple to disassemble and install. When I disassemble a car, I repair it more than a motorcycle, and I'm surprised how much easier it is to replace parts.
I will also ask one more question. My brake discs are in good condition. However, cosmetically, I did not like the color of the front cover at all. I'm thinking of sanding and painting the worn front cover surface.
Or is it possible to replace this brake disc with an air-cooled brake disc after removing it?
I replaced the front hub and mounts.
I will write something about zrot.
Zrot is in the position of turning fully right or fully left.
It hits the ABS cable.
Is this situation normal? Could I have installed the plate incorrectly before?
I also want to say one more thing.
-I replaced the rims with tin rims.
-I changed the tires to 165/60/14 Kumho HS11 model.
-Shock absorber mounts were also changed.
After these 3 variables, the car became very different. (in a positive sense)
-Road noise reduced by 70%.
-Taking off and accelerating the vehicle has become easier.
-When I let go of the steering wheel, the car goes straight.
I wonder what led to such positive change.
I think the shock absorber mounts and tires make the most impact.
The side wall stiffness and grip effects the steering feels and self centering
As does the tyre pressures
Different tyres have different, cost, noise levels, grip in the dry/wet/snow/ice, economy, comfort and wear
You have to pick the best compromise for you
I look at price, noise and wet grip
