Hello everyone,
Following the repair of my ECU by ACTronics for a lump sum of €259 excluding VAT, I received a document which told me that the throttle valve could be the cause of the breakage of the electronic box and that it should be replaced.
I doubted this diagnosis and said to myself that the breakage was probably due to the heat in the engine compartment.
However, as I wasn't sure, I replaced the throttle with a new Kamoka, bought for 120 euros from Autodoc.
After repairing the ECU I simply reconnected it and the car started and run perfectly.
According to the document shared by Koalar, this throttle should have had a resistance of between 5 and 25 ohms at the central contactors of the connection. This document refers to the Fiat 500 1200, so we're not sure if these values apply to the Panda 1200 4x4 60 hp. The value measured on my old original throttle is 87 ohm and the value measured on the new Kamoka is 90 ohm.
Given the low price of the Kamoka throttle, I'm going to keep it and keep the old one in case of problems.
Thanks to Koalar for his invaluable help.
I hope this topic will help others who encounter the same problem as me in the future.
