Hi everyone
On my sisters seicento 2003 we had the cambelt replaced and at first it didn't start at all and turned out the bottom pulley wasn't done up tight enough, this was then sorted
Then when you went over a certain speed the engine light flashed, engine detected a random misfire as the timing pulley was out ever so slightly, it has now been moved and this has cured that problem
But now every few days or so the car starts up on first attempt and then cuts out, it Turns over but won't start only on the 4th attempt it will start them comes up with the fault codes, but it runs fine, htc leads have been changed and the crank sensor too, any ideas?
Like I said the car runs fine and it's strange how it happens every few days and starts on the 4th attempt
Any help much appreciated
