I did read a fair bit of similar problems on this forum, and I'm not looking for an immediate solution, but rather help with diagnosing the problem:
As we are on the road (in Italy, our van's home country) currently I don't have all options available to me to work on it... So this is what happened with our X250 3.0 2007 today.
I was cruising on a fairly flat road doing about 70 km/h in 5th (so not too much load) when the engine suddenly cut out with the MIL coming on. I have a little BT ODB dongle with me that told me error code P0089. The engine restarted and I continued driving, I also cleared the code to see if it came back. I then wanted to overtake a tractor a few km later doing 30km/h and just when tapping the accelerator (or shifting back) the engine cut out again. This time I just restarted it while driving and overtook the tractor.
We then drove another 70km including very steep climbs of 10% and more without any problem. The van drives like it always does. We have quite some cargo (it's a camper van) so we needed every bit of power from the engine to get up the mountain.
We now parked up for the night and I am wondering what I can do here to find the issue. I have tools with me (but no power tools) and I could disassemble the front to get to the fuel pump and regulator.
The fuel filter was replaced before we left (about 3000 km ago).
With Car Scanner and the OBD dongle I saw fuel pressure between 300 bar and 1400 bar, revving the engine while idling, I read in the training manual the fuel pump is directly driven by the engine so I guess these readings are normal. While idling pressure is stable.
Since the engine can be restarted immediately I would suspect an electrical issue, or faulty sensor. Even the solenoid regulator could be an issue.
Is there anything I can check/diagnose/clean while on the road? Or should I just leave it alone and drive to a dealer if it keeps coming up?
