General  Oil level on 1.2's
roadster1_98
Falkirk
Checked my oil tonight (most new cars I've had have used some in the 1st 1K) and it looks like its overfilled. I thought the oil should be in between the marks??? cars is on level ground. Anyone else seen this?
fiat's should be at te top f the hatched markings
to give you some idea your engine takes 3 litres and between the top and bottom mark is one litre of oil
and you'll find that new fiat engines don't burn much atall
Excellent thats what I like to hear thank you sir.
Three litres!!! its a wee tiddler ain't it :D
Mine is just over the hatched markings and I haven't added any yet at just over 800 miles. Fiat must have slightly over filled it. I suppose it's better that way. My 1.2 will be getting a bit of a run over the bank holiday weekend as I'm spending a couple of nights near Brighton which from Manchester where I am is about 250 miles. Oil still looks like new up to now.
are ou wiping the dip stick properly and allowing the engine oil to setle after a run
it's just i have never seen a fiat over the top mark on pdi
i once found a kia picanto with twice the amount of oil it should have in it
Our Cinq Sporting, which we have owned from new has never used a drop in the 57,000 miles that we have driven it. From one service to the next the oil level on the dipstick never moves.
The same is true of our '96 VW polo which will be replaced by a '500. That (the polo) has done 176,000 miles!
I always use Mobil 1 incidentally
Vic
