General Oil Leak
General Oil Leak
nkendo
liverpool, United Kingdom.
Hi
I am the owner of a Panda S999CC, and have discovered an oil leak, coming from around oil filter or oil res, its only a slow leak, but am just wondering what are the implications of it,and how do i go about fixing it,what am i expected to pay?
Cheers Neil
Most Pandas seem to leak a bit.
There are a number of things which can cause it to dribble around there:
camshaft cover gasket (fairly messy but cheap DIY job)
camshaft breather (rubber) pipe (even cheaper - about 1UKP - don't forget the flame trap) - I know this leaks down the back, but it does get everywhere, and can be difficult to locate from the bottom of the car.
sump rusted through (Puntos are (in)famous for this) (getting expensive for parts)
crankshaft seal (getting expensive for labour)
late addition to list:
camshaft oil seal ( will have to find out how difficult it is, as the CLX has started to drop quite a lot, and it looks like it may well be that seal..)
even later addition to list:
oil filler plug loose when fully in..
(I'm now fairly certain my (most) recent leak is this - it's a tight fit over the first portion of the plug, but when actually "home" it is so slack you can rattle it about[:0]..)
I will confirm or deny this over the next few days.
probably final addition to list:
The oil filler plug was leaking, but it's not my main oil leak on that side.
I will have to see if the gasket set I won on Ebay the other day is complete enough for the job:(
Anyone know the going rate for stretch bolts??
Sounds daft, but if the dipstick isn't fitting properly you can also get this effect. Happened to me once in the lil' white Panda :)
Steve the geriatric Panda and Beagle freak
My white Panda 1000CL - 31-08-1989 to 09-03-2004 (may she rest in pieces :()
J*** ***: Gorgeous little red Panda 750L in good condition - screaming for me to rescue her :)
I've had eight Pandas and the worst oil leaks have all been caused by rotted sumps which I've repaired with an angle grinder and plastic-metal !
HHmmmmmmm
