Technical Oil Leak
Technical Oil Leak
Southeast
Dear fellow Fiatorians
I have a 1997 1.9TD Fiat Ducato and it leaks oil from two different places under the engine bay. Any ideas where it can be from or is it a case of climbing underneath wiping all the oil off and try to locate where it is coming from.
Just wondered if they are prone to leak in certain areas.
Any ideas will be very welcomed and appreciated.
Many thanks
Paul
How long is a piece of elastic?????? You will have to start looking yourself, take it for a run and then park it over a clean area, put a large sheet of paper under the engine, you will then be able to see the general area the oil is leaking from, it's then a matter of following the trail to the source.
