If you have any idea where to find a thread, please point me in the right direction.
this took some finding..
https://www.fiatforum.com/cinquecento-seicento/34318-new-induction-system-cc-sc-0-9-1-1-1-2-a.html
Rear Suspension. Modified arms and Avo coilovers off the cage
Gearbox. Home made short shift kit - GIves 60% reduction - I can make these if anyone wants one????? (Oh and an oil leak!!!!!)
Ride: Very stiff and corners without any roll. Rear wheel camber is 6.5degrees and get good grip when fast cornering. Allergic to speed bumps and potholes alike!
Hi Rally Cinq.
It is designed for track only, but has a full MOT as of friday, so i drive it one the road to shake it down and annoy fast car drivers with more ego that horsepower!
I like what you've done to the rear suspension, how much did you modify the rear arms though? Tweaked where the bottom of the shock absorber usually bolts to for a different angle or a bit more?
More info and pics of the short shift setup would be nice if possible
btw are you meant to have a seal around the rear glass?
Hi BlueDanGroup
I had to extend the rear arms by around 40mm. The avo coilovers have the same diameter mounts as the original shocks, so just extended it with a scalloped out bit of box section. I have also braced the sides of the mounts back to the arm to give a bit more strength and seam welded the edges of the arms to spread the load if required. Probably overkill but better than killing me.
The angle of the shocks is pretty close. I tried to get the shocks as vertical as possible. (This seemed like a logical thing to do - dont ask me why!) The mounts are a few degrees off, but the slack is taken up in the rubber mounts in the end of the coilovers.
This idea (fiddling with the levers on top of the gearbox rather than the stuff inside the car) was mentioned in another thread recently, dunno if they have made any progress on it though.I will try and get some pics of the shortshift setup. Everyone seemed to be worrying about moving the lever pivots and lifting the lever up in the air. I turned it on its head and played with the length of the levers on the gearbox itself.
Would look better than "ɹǝʌo ʞɔɐq ǝɯ lloɹ ǝsɐǝld"Its amazing what you can do with a hacksaw and a welder.
Come to think of it. That is what i'm going to scrawl on the back of my car!
"Its amazing what you can do with a hacksaw and a welder!"
If that's saving weight than the holes where the lock barrels should be must be creating loads of dragRegarding the seal on rear window. The rear screen is bonded in and the seal is just cosmetic. I took it out ready to wrap the tailgate in green. Or would you prefer me to tell you i was trying to save weight???![]()
If you are in Gloucester at any time, come and take it for a spin!
Perspex windows: I made a set for RobW a few years ago to go in a Cinq 899 to do the mongol rally. There was absolutely no weight saving whatsoever! And they are an arse to clean and scratch so easily.
