So from those reading does that mean Dave could put a 3.81 Kohm resister across UFI plug to indicate a 10 degree Centigrade reading and if the UFI sensor is faulty the resistor would give a median reading for test purposes?
YesSo from those reading does that mean Dave could put a 3.81 Kohm resister across UFI plug to indicate a 10 degree Centigrade reading and if the UFI sensor is faulty the resistor would give a median reading for test purposes?
That vertical drop recorded on your MES seems similar to what my MaxiECU showed when we tested, no gradual decline.I tried AlfaOBD but it won’t work unless paid for. Now removed from computer. AlfaDiag appeared in various places which looked dodgy so did not download.
MES is now working fine. Who knows why it refused to show live values.
New fuel filter seems to have removed the high fuel temperature errors and I have connectors that font have broken release caps. However I am getting a spike drop in fuel pressure that throws up the warning light and it’s getting worse. It spikes down and straight back up.
It seems to be be consistent with pressing the throttle pedal. But I’m not sure of that because it doesn’t happen at idle.
Fuel pressure has reached 550 bar at 2000rpm. The pressure drop is so steep, I think it’s being commanded by a valve or signal to a valve.
Any ideas what can cause the fuel rail pressure to drop to zero and jump straight back? faulty valve? Faulty pressure sensor?
At the moment we are guess and making assumptions at to what we are seeingFuel pressure is around 300 bar at idle. It’s goes to around 550 at 2000 rpm. The transient fault happens when I try to accelerate.
What will disconnecting the injectors signal wires tell us?
I note the 6 Bar reading is not far from the 7 Bar my MaxiEcu recorded at same point when we tested it the other week.With injectors unplugged the ECU sends no data that can be seen. Engine speed and injection pressure parameters remain empty.
I recorded engine start (glow plugs u/s) as shown. Engine fired up at around 250 bar and similar rpm. I don’t know if the rate of pressure rise during cranking is normal. It is similar to what this engine has always done.
I took it for a drive with MES recording and got the fuel cut off the moment I properly pressed the accelerator. Fuel trace did the same jab down as I pressed the accelerator.
Once it has done that and raised the ELM, I can work the accelerator any way I like. Power is reduced ( I guess It’s in limp mode) but the pressure trace stays up. There are no more lurches as fuel momentarily cuts off.
Are you sure your video shows otherwiseI recorded engine start (glow plugs u/s) as shown. Engine fired up at around 250 bar and similar rpm. I don’t know if the rate of pressure rise during cranking is normal. It is similar to what this engine did when warm. Here it’s at summer ambient.
