johnsb20
Hi Everyone
My 2006 Grande Punto has just failed its MOT 7th year running
this time it failed on rusting sills.
The drivers side at the back is defiantly gone no doubt, theres is a hole through the triangle bit as it curves up to the wheel arch but the tester said there was holes all along both sills.
When I have looked at a picture of the underside of a GP online its supposed to have holes 5 on each side, the holes are rusty and have gone a bit bigger but they are the only holes in the sills do you think this should really be a fail? I have prodded with a screwdriver and all the other metal around the holes seem ok not managed to poke any other holes through.
These where the failed points.
Offside Rear Inner Suspension component mounting prescribed area is corroded to the extent that control of the vehicle is likely to be adversely affected sill (5.3.6 (a) (ii))
Offside Outer Suspension component mounting prescribed area is corroded to the extent that control of the vehicle is likely to be adversely affected sill, front to rear (5.3.6 (a) (ii))
Nearside Outer Suspension component mounting prescribed area is corroded to the extent that control of the vehicle is likely to be adversely affected sill, front to rear (5.3.6 (a) (ii))
