Hello
I have a problem with my Fiat punto 1.2 (2012). I just bought it two months ago, so I don't know much about the maintenance history. The issue is that sometimes when the car is warm and I am driving on the highway above 3500 rpm, the engine management light comes on and it goes into limp mode. It is not always the case, and I can often drive 25 km above 3500 rpm and everything goes well. When the car goes into limp mode, I can immediately turn the car off and on again, and it works normally. I don't really know what it is myself. The error codes that came up are p0300 and p0302. Now, the garage has also reported that it had a misfire in the third cylinder. I replaced all the spark plugs and ignition coils, but that was not the problem. The cables between the spark plugs and ignition coil have also been replaced, and a cleaning agent has been added to the fuel.
What could be causing the issue? What steps can I take to see what is causing the issue?
I would really appreciate your help.
- Model
- 1.2
- Year
- 2012
- Mileage
- 150000
