The car has done a very easy 4.4k miles and is only 11 months old.
perfect time to use a break-in method,
to get the oil control rings doing their job,
AND it's doesn't cost anything..!!![]()
With all those fault codes, I strongly suspect your battery is FUBAR.
Why do you think that?
Years of fiat group products!
Xmas tree dashboard usually equals a knackered battery.
Get it checked.
If all they've done is to clear the error codes and put a cupful of oil in, then sadly I'd bet money you'll be back at the dealer before very long.
UPDATE. Car towed back to dealer again with exactly the same faults. Been at main dealer (Threeways) for 10 days but they only looked at it yesterday. Battery reported as OK.
Hi,This is not good news; condolences. Clearly there is a fault with your car and I'd insist on it being properly diagnosed and repaired before accepting it back.
By any reasonable measure of customer service, not even looking at it for 9 days is beyond appaling. If you haven't already filed a complaint with Fiat CS, I'd suggest you do that now.
If they say again they've reset the error codes and all is now well, but aren't able to give a credible explanation for its behavour, then I'd refuse to take it away.
Have they given you a courtesy car for the duration?
I had to hire my own courtesy car locally as I was due to go on holiday the following day. Fiat CS say they will refund the hire. That car has now been returned and I now have a hire car provided by Fiat - though it took them 4 days to source one!
Sad thing is, I have now lost confidence in the car and it has marred the enjoyment of what should be a fun vehicle. I have zero confidence in the dealer, which is a 140-mile round trip from my home, but will not accept any BS from them this time.
There's no finance involved - paid for car outright.
Today, Fiat Italy called to day that Fiat Technical were now involved and had suggested changing the spark plugs. Bear in mind that this is a car that has not yet covered 5K miles, how feasible do you guys think that the plugs could be causing these dash warnings and intermittent faults?
