Technical Issues with engine mount
Bporsch
West Lafayette, IN
Hi! I have a 2016 fiat 500x that has been experiencing issues with the engine mount. I'll preface this post by saying I don't know much about cars.
I took it to a shop 9 months ago, and they said I had to replace all of the engine and transmission mounts in my car. They charged me close $2.5k to have it all done. Luckily my warranty covered everything except for $500. It was in the shop for 12 days total; they had issues getting the right parts (lost in shipment, wrong part, etc). Just by doing a basic Google search, I don't think it is too difficult to get a hold of those parts. I had the feeling that I was being scammed, but because of my lack of knowledge, I didn't question it too much.
Fast forward to now, I brought my car into a second shop because it was starting to shake again. The second shop said that the engine mount had a plastic piece that they needed to be replaced because it was starting to break down. The second part of the engine mount is apparently cracking and will start leaking fluid.
I am extremely confused why it would need to be replaced less than a year later. The first shop has a policy where they will fix any mistakes that they have made a year out from the original repair. They said it shouldn't cost me anything, but I don't trust them. What do you think could be causing these issues with the engine mounts? Was the part that they used faulty? Is it from an installation error?
I'm at a loss at would do this. The guys at the second shop gave me the original part that they replaced. I can take pictures if that would be helpful. Thanks in advanced for any information!
Change your repair shop for one that has an official accreditation to a recognised trade body. It does sound suspicious. I have driven many hundreds of thousands of miles and never seen an engine ounting fail as you describe, so its an unusual fault. For two to do so in just a year is very very unusual. It may be they were not changedat all in the first place. Even oil filled mounts should function at a basic level once punctured. CHeck with a dealer if your car actually has oil filled mounts, these are most often fitted to diesel engines.
Shaking of the engine is more likely to be a running issue and nothing to do with the mounts. Before spending a lot of money make sure all the cylinders are running. Get the spark plugs and ignition leads changes and check the ignition coils work properly via an engine diagnosis.
I will definitely do that, thank you!
What sort of issues are you having with the mounts? Is it noise, vibration or both?
I still have my original mounts since I bought the car brand new back in 2016. No problems with my mounts. I prevent problems with rubber parts by using a rubber protectant spray made for RV's.
