@Michael Dranfield,
@Visconti,
@g8rpi - Thank You for your replies, I will try to follow your advices. Actually I already resoldered almost all the pins, but switching the burnt capacitor is still one fault to fix...
I bought a chinese fake VAG COM cable, with a CH340T chip - at the end of the day, after screwing up hours while trying out drivers and stuff, finally I was able to connect to the ECU using unregistered
(not for too long, I will buy the full version, when my proper ELM327 USB cable arrives) MES.
I attached an image which shows the stored errors according to
MES. It looks a bit worrying to me. I clicked the clear errors button, and now I cannot read the whole description of the single errors. After restarting the car, blipping once the throttle, shutting it down almost inmediately, and then reconnecting to
MES - I experienced no errors, even though the engine was running like before. I guess I should have waited for longer or just go for a ride, to reproduce the previously stored errors.
So ...
P0201 - Cylinder 1 injector - No signal - Stored - Light ON
P0300 - Ignition failures (generic) - Signal low - Fatal - Light ON
P0301 - Cylinder 1 ignition failures - Signal low - Fatal - Light ON
P0136 - Lambda 1 Signal below catalyser - Signal low - Stored - Light ON
P0302 - Cylinder 2 ignition failures - Signal high - Stored - Light ON
Where should I go next? New ignition cables + coils (at Cylinder 1+2) + spark plugs, and also new injector (at Cylinder 1), and new Lamda sensor?
Thank you for your help in advance!
w21.
