Planning on pulling a trailer with the van so was wondering if anyone has fitted a good brake upgrade?
If true that would be great! but maybe a bit priceyI think the Selecta has bigger discs and are a straight swap
In the italian forum we have a little Tutorial for mouting the front brakes of Panda Selecta on 2wd Pandas.
It is a great upgrade, without cutting anything.
You just change the front brake calipers & discs.
In Italy we use to add the 7" brake pump of last Pandas.
The "last" Pandas have been produced between 2001 and 2003, with 1.1 MPI engine (multipoint).
The front upgrade consists in :
Brake calipers - Front disc (240 millimiters instead of 227) - 7" brake pump
I'm not sure of the translation, but I'm referring to the pump that you activate pushing the brake pedal.
This is the link in our forum, in the future I will translate it :
http://www.panda4x4.info/forum/viewtopic.php?f=36&t=6253
We fitted stilo discs to the rear & a balance valve which works brilliant but how about just braking the trailer ?
Fading brakes may also be due to old braking fluid (don't know if the mechanic also flushed/changed the fluid when he changed the pads?).
Braking fluid attracts moisture/water over time, resulting in a lower boiling temperature, which leads to fading brakes when applied over a longer time.
But do Selecta brakes really make such a great difference? Is there anyone who can tell ?
I'm not sure of the translation, but I'm referring to the pump that you activate pushing the brake pedal.![]()
