Technical Instrument cluster display
alandrill
uk
I've read through the various posts regarding the instrument cluster failing and I guess that I have the same issue with the car being 2008 and getting old.
I had a failure of the 20A ignition fuse following a wiring problem to the starter motor, I think it was shorting. New starter sorted this.
Car sat for a while so could have got damp? The instrument cluster had the gobbledygook as mentioned elsewhere and now it just glows with ignition on, no numerals/digits can be seen centrally. The outer ring lights up when driving lights put on.
Is this the LCD failure mentioned in the other posts? I checked the instrument fuse (5A) and it was fine.
Thanks in advance for any assistance.
  • IMG_fiat2.pdf
  • IMG_fiat1.pdf
You need to remove the entire clock and read the factory number of the display.
safe_ltr
Fiat 500 Speedometer replacement LCD Pixel Repair - YouTube
If you have an automatic transmission, the display is very difficult to buy.
