gregdoc138
Hi all. Thank you very much for the privilege of letting me join your club..
Hi,I have a 1996 fiat ducato motor home. It has a wooden dash but the lights behind dashboard do not work. Please can anyone tell me how to replace these please.
Your vehicle will be based on an x230 model Ducato. To confirm see first three numbers of VIN which will read ZFA230xxxxxx.Lights behind dashboard that illuminate heater controls
It's different on the 230 , @Communicator . You have to remove the lower dash , to be able to remove the radio heater panel . You also need to remove the upper switch panel to release the radio/heater panel . However i will add that this is more likely an inlaid wood dash , not solid , due to the shape , but yes it does mean removing the radio .Access on my "facelifted" x244 model is from the top, with a screw hidden behind the ash tray.
very thorough explanation
