General Head lights
General Head lights
Right still stuck. So passenger side all bulbs work.
Drivers side when it's on low beam it seems to go to high beam. Then when I flash nothing happens. But when it's just side lights the high beam works. Somebody please help me out
Hi, Please stop starting a new thread every time you post on forum about your headlight problem.
Please do add to the thread you have already started re: headlights.
You will get more help doing so.
It sounds very much like there is a fault with the ground (-ve) connectors or wires to the driver side headlight.
0-20volt range dc
One lead to head lamp bulb -ve
Other lead to battery-ve post
Take a reading with low beam on
Take a reading reading full beam on
Take a reading headlight Flash position
Yes battery negative post
Yes bulb -ve wire
Yes with bulb fitted
