Technical Dashboard lights dont come on
PIonut
Mures
Hy all.
I have a problem with my Punto 199 2011 petrol car.
The key turns normally but there are no warning lights on the dashboard, the radio does not start and the top light goes out.
After I stop, I turn to 0, there is a rapid ticking of the relay in the area under the steering wheel and all 4 needles move, go up and down a little.
If I try several times, the warning lights and the radio come on and I can start the car.
The battery is ok, I measured it and tried it with cables from another car. I changed the remote control battery today. I also removed the - terminal for a few minutes. The same.
And the central locking from the remote control does not always work.
I've had similar problems before but rarely, I used to turn on the ignition but when I turned to start the engine it didn't work. I would bring it to 0 and then it would run. But the warning lights and the radio always came on.
I don't have a spare key.
Thank you!
Model
Evo
Year
2011
