The vehicle will be an x244 model on which the hazard warning, and direction indicators are controlled by the Switch Control Panel (H090), which is buried in the dash behind the auxilliary switches.
The wipers are controlled by the column switch, with no obvious connection to the Switch Control Panel, and hence no obvious common factor, except connector D001A
Were both problems noticed at the same time, as this would suggest a common factor, or was one fault noticed before the other? Has the vehivle been laid up immediately before faults noticed?
Relevant annoted eLearn drawings and three of my own which may help, are attached but I am still thinking.
