Technical Hard to start Ducato 1993 1.9d camper
Just a question (unless I’ve missed it somewhere) what mileage has it done? Could be a compression issue if on the higher side. Just a thought
Good point @Greasytrucker , it is something I should have asked, although many camper vans seem to be quite low mileage, unlike work vans of similar age.:)
In basic terms for the OP , diesel engines are also known as CI engines which means Compression Ignition, as in no or low compression equals no ignition:(
The heat of the compressed air ignites the injected fuel, hence they need good compression and with some engines more than others the use of heater plugs etc.
For the moment I would rule out the cheaper options first, before worn out engines.;)
hi, compression test performed all cylinders read around 300 psi, i think its a fuel supply issue now looking into the fuel filter/primer it looks like it has a pump in there, there are 2 connections to the filter/primer i presume one is a water sensor but dont know what the second is, ive traced the wires back to a relay bolted to the chassis above the battery and the other runs into the cab somewhere i presume to the ignition i dont get any voltage across this when the ignition is on
On the ones with a hand primer it is not unusual for the seals to fail on the primer pump allowing air into injector pump.
You may be able to test by disconnecting the pipe to the injector pump and when working the hand primer see if clean air free fuel is coming out.
Sorry I got called away, and must have pressed reply in error.
I am thinking that on previous discussions about engines pre 2000, some at least did not have a lift pump, but relied on the transfer pump contained in the injection pump. In such systems the fuel supply line is at negative pressure, and air will be drawn into any small leak e.g. in primer daphagm. Also fuel can drain back into tank, if vacuum is not held.
I doubt that there is a pump in the filter primer assembly. Second device could be a diesel heater.
This is an earlier Fiat design engine, but I had an 2003 Doblo with a Lucas Epic fuel pump that relied on suction from the tank and did draw in air from a dodgy fuel pipe connector seal.
It was a long time ago so not sure if a primer or not.:)
