Hi guy's , time for me to ask another question .
Vehicle ; Ducato 2.8 TDI , x230 , year 2000 . Subject ; Gearbox selector cables .
Question , my research is beginning to indicate these cables can be removed and replaced separately , is this correct ? .
Currently the cables in my van , are fixed together by a plastic moulding , where they pass through the floor . Sorta indicating it's a complete unit , and should be replaced as such . Now , my cables themselves are fine , still working smoothly , and correctly , despite being what i suspect is something like 25 years old . I think these may be the originals to the van . Even the outer sheaves are showing little sign of wear , certainly no chaffing .
However , i wish the same could be said about the floor moulding itself . On the face of it , it also looks fine . A little sun bleached perhaps , but otherwise okay . However the rubber seal on the underside is anything but , this is quite literally falling apart , in particular where the cables pass through !
My worry is , that this is a good place for damp , even water to permutate through into the inside of the van , and i want to address this issue , before any problems begin to make themselves known . I can tackle the bleaching , and even repair the rubber , but to be able to do this i may need to remove the fitting itself .
My manual seems to indicate the cables can be removed , and replaced individually , and i just want to clarify this before i proceeding any further .
Any of you guy's know any better ?
Thanks guys , Mickey .
