I considered going to Halfords a good while ago as they do a free analysis of battery condition, but the battery i was wondering about has a very large capacity and I just hadn't driven the car enough to top it up. It was interesting researching them on youtube though.
The GPs and EVOs i drive all drain the battery very quickly if the engine isn't on. It must be some kind of design fault, or a faulty car part I don't know about. I went through a phase of having to bump start a car every week, and perfected the technique. I've seen the super batteries used by scrap merchants and would like one anyways.
The electrostart that you've linked above seems not to be a battery, it seems to be a transformer of some description that'll do the job. i.e. it'll take the last bit of charge in the battery and boost it, or steal some charge from another car.
As a "driveway greasemonkey" it's well worth cultivating a relationship with your local Halfords. If for no other reason that they're open at weekends so sometimes can really save you if you need something when other suppliesr, like factors, are closed. Their range of stuff on the shelves - relative to doing car repairs - doesn't compare to a Factor but they do have a lot of common stuff and offer services like the battery condition check which I've availed myself of at two of their branches up here. It was very professionally conducted and they didn't try to pressure us into buying a battery.
Supercapacitor jump starters are a relatively new thing and I find them very interesting. They consist of 5 or 6 super capacitors with a clever switching circuit controlling their operation. In very basic terms each capacitor can be charged up to around 2.5, maybe 3, volts - I don't know exactly how much but it's in that region. The device is in a discharged state when stored and won't hold charge over long periods like a conventional battery so has to be charged before use every time. Now here's the clever bit. Most "flat" car batteries - the sort of situation when they just won't quite turn the engine over because the interior light has been left on overnight - will register something like 6, 7, 8 maybe 9 volts when checked, this won't be enough to kick the engine over but it's way more than the somewhere around 3 volts needed to charge up one of these capacitors. So you connect the jump pack leads to the vehicles "flat" battery and press the command button to "charge". inside the pack the "clever" electronics connects the 5 or 6 capacitors in parallel to the "flat" car battery - so each capacitor is being charged as a separate entity until it's fully charged at around 2.5, maybe 3 volts. Most will have a readout which lets you see how this charging is progressing and indicates, often with an audible beep, when fully charged. Then all you need to do is press the button which initiates use and you get about 10 seconds with most of them, to get to the ignition key. The unit then gives an audible warning that it's ready and you twist the key to start the car.
And how does it perform this miracle? well it uses the residual voltage in the battery to charge up the capacitors - only needs a few volts to do this but most of the ones I've researched won't charge off battery with less than 5 or 6 volts in them. - which is actually likely to be most of the "flat" batteries you come across. It's not going to charge up from a truely FLAT, flat battery though so there are limits but you can always charge from another vehicle - only takes on average about 3 minutes - or a USB lead with many. So you're nearly flat battery charges up the capacitors in parallel and lets you know with a beep and on it's display saying "ready". So now you press the initiate button which gives you about 10 seconds until it changes the way the capacitors are connected to a series connection, So now all the capacitors are connected "nose to tail" like batteries in a torch. This means that you have all these batteries adding their voltages together. So, lets say there are 5 supercapacitors charged to 2.5 volts each. That gives you a total voltage of 12.5 volts ( it's actually a bit more than that because they charge to a bit more than 2.5 volts each, but you get the idea. The device will give you a beep when this connection is completed and you now have it supplying that voltage to the jump leads so you can twist the key and, as long as all that's wrong with the vehicle is a "flat" battery, it should kick into life. Capacitors, by their vary nature, don't hold a charge for very long so you'll only get a limited cranking time before you need to recharge the device, It's not like doing a jump start from another car with a nice big battery of it's own but it should be enough to get the car started.
Here's a short video showing basically how it's used:
I like the idea of this type of jump pack because there's no internal battery to degrade or that you have to remember to charge up from time to time - a flat jump pack is absolutely no use to anyone. Obviously it has it's limits in that it's not going to charge from a completely flat battery and it's cranking time will be relatively short but I recon it'll deal with most cases of a car, perhaps left overnight in freezing winter conditions, which just fails to start in the morning.
