Hi, which gearbox oil do i need? I've checked the EVO manual but it doesn't say which I need.
There are people that keep dealers in business, I'm starting to think the OP is one of them.What's wrong with you?
That's the very stuff. Note it's rated as GL4 plus? I've been researching this as it's not actually listed as a spec in the API listings. API GL4 and API GL5 yes but nothing with a "plus" in their official spec lists. However there are a few manufacturers now listing a GL4 plus oil and I believe it to be a lubricant to the GL4 spec with certain enhanced anti friction properties but without the additives which erode "yellow metals" - which is what caused all the problems when people used a GL5 oil in a 'box for which GL4 was specified. For those who've not heard of this problem it was that the GL5 caused rapid excessive wear in components like synchro rings, bushings, selector forks and other yellow metal components. I believe now that most GL5 oils are blended so this effect is very greatly reduced but, personally, I wouldn't risk it. If a GL4 is specified I wouldn't risk a GL5 - Mostly GL5 was historically used in units with high load and high shear, so final drives, worm gears etc. You need to be aware of this when being given advice by well meaning but relatively ignorant sales people. Typically the argument is that GL5 is a newer product and heavier duty so protects your gearbox better than GL4. It's a bit like comparing oranges and avocados, just makes no sense when you "know"
I bought 2 litres for our 1.2 Panda (169 model) and the same again when I changed the oil in my boy's 2012 Punto in both cases there was a small amount left over.I think it's around 1.6 litres
That is the actual Fiat standard recommended oil. used to be manufactured by Selenia which was owned by FIAT but they were taken over by Petronas hence the rebranding to Petronas. You probably couldn't buy better. Sometimes buying the actual oil recommended by the manufacturer does cost a "bob" or two more but it's not as if you're buying gallons of the stuff or changing it every service so the cost is minimal in the long run. If the 'box is drained, one litre won't be enough.The fiat gearbox oil looks non standard at gl4 plus. It's difficult to understand why fiat didn't use gl4 or gl5. So I possibly paid a slight premium for this stuff.
The vendor is shop4parts and on the back of the bottle it specifically mentions fiat. The last thing I want to do is accelerate gearbox deterioration.
I bought one litre and presume that'll be enough. Anyone know the capacity of a standard Evo/GP gearbox?
Gearbox doesn't normally use oil unless there is a leak. Best to change the the oil after a fairly large mileage, say70,000. I don't think there is a specific recommended oil change interval for the gearbox, but may be wrong.Any harm in topping up instead of changing?
Nope, top up whenever needed. I check transmission oil level at annual service. I'm under there to do the oil change so doesn't take much longer to whip the plug out of the side of the gearbox (car needs to be level though of course). If needed, top up. but if level is low enough to need more than a teacup full then I'll be looking for the leak. I would drain and refill with new oil every 50,000 miles unless the manufacturer calls for a smaller interval. I don't believe in "filled for life". I always drain the oil into a nice clean container - usually an old engine oil container with he side cut out - and look very carefully for "sparklies" and other "foreigners" in the old oil. I also would do this after having been for a good drive in the car, maybe 10 to 15 miles minimum, so the oil gets nice and hot so is thinner and drains better.Any harm in topping up instead of changing?
