Hi, I've been a Fiat owner for a couple of years now but have just decided to change my Brava for a Mk2 Punto. I've only just got the car but I'm already running into problems. Everything seemed fine on the test drive but once I was on my way back home, as the engine got warmer, the oil pressure light came on at idle. As I accelerated away though it went out so I wasn't too worried as the manual says this is ok. The majority of the journey was motorway which seemed to go ok but when I got stuck in traffic and the engine was idling more and getting even warmer, it seemed to need higher revs to make the oil pressure light go out. The engine also started to be come much noisier, particularly on slight acceleration
. I've taken her for a short spin today and symptoms were the same again. Seems totally fine when cold but problems increase with temperature.
Oh and on a separate note the clutch is also slipping at highish revs.
So basically I think I've bought a proper wrong 'un and would just like any advice as to what my best options are. Is it even worth paying any money just to get the problem diagnosed or should I just get rid of it straight away and cut my losses?
Any help would be much appreciated. Thanks in advance
