D4nny8oy
Established member
I'm not trying to rip the p***, it's just that you see so many people who've read a few Max Power magazines and think they can build/do anything.
If it all works out ok, then respect where it's due- I converted my XR3i to an RS Turbo despite many telling me it wasn't worth it, especially spending about a year collecting various parts, checking wiring diagrams and so on.
A wastegate controls the speed of the turbo (and therefore the boost). When the preset pressure is reached, say 15psi/1 bar, the diaphragm in the actuator overcomes the spring holding the wastegate closed and opens it, allowing exhaust gases to bypass the turbine wheel thus preventing the turbo from speeding-up further.
A controlling solenoid can be used to manage the actuator electronically- making it hold maximum boost right to the red-line, or gently tail-off to prevent the risk of leaning-out, or 'bleed' the boost in gently to cut down on wheelspin. It can also be used to provide a short period of extra power for overtaking ('Overboost'- like in modern JTD's).
It's possible to run without a solenoid, plumbing the actuator straight into the compressor side of the turbo (I ran my RS like this for 2 years at 20psi, I only went over to a boost controller recently for more stability), only problem is it would probably leave the management lamp on, and maybe run in "Limp mode".
A dump valve is different altogether. When the throttle is wide open, the 15psi is flowing through easily no problem. When the throttle is then snapped shut (for a gear change) the pressurized air is now up against a wall (throttle butterfly) and backs-up until it ends up going backwards through the compressor vanes, this creates a 'chatter' sound as the blades 'chop up' the air and can cause the turbo to stall, creating lag when the throttle is reopened. A dump valve can be used to help relieve the pressure. They can be atmospheric- where the boost is released to the outside air, or recirculating- where the boost is directed through a pipe back into the inlet side of the turbo, where it loops around without disrupting the compressor wheel.
Many, including yourself I'm guessing, regard the atmospheric version as a little 'chavvy'. I'm certain Coupe's had the recirculating system as standard so you could use this, though some creative plumbing would be needed for a Stilo.
Or you could forget the dump valve, and enjoy some 'chatter'.:devil:
It shouldn't cause problems unless you're running high boost or a roller-bearing turbo.
Incidently, what ECU are you going to be using? I wouldn't think the standard Stilo ECU and MAP sensor can handle positive (boost) pressure as there's no need to in standard N/A trim. And I'm almost certain the Coupe ECU wouldn't be compatible with the CAN network, causing multiple errors.
Have you made sure it all fits in the engine bay?- there's not a lot of room for the standard manifold/Cat assembly from memory.
Let us all know how it goes.
