hodgy18
Established member
- Joined
- Apr 27, 2017
- Messages
- 172
- Points
- 160
I got quite a shock as well when I saw how much the price of the harness has gone up since I bought mine, I paid about £35 when I purchased it 2 years ago, the part no is 20-101-IGN so maybe a bargain could be found somewhereThanks FiatMatt94 - my car doesn't have the steering wheel controls, so will be suitable. Can't believe the harness is nearly same price as stereo![]()
Does it make a difference with harness, that current radio doesn't switch on/off with the ignition? Or will this harness allow the new one to do so?I got quite a shock as well when I saw how much the price of the harness has gone up since I bought mine, I paid about £35 when I purchased it 2 years ago, the part no is 20-101-IGN so maybe a bargain could be found somewhere
YesDoes it make a difference with harness
Thanks for that - I'll have a lookFiat Canbus adapters are £12-20 including shipping direct from china
I can't recommend any as I haven't used them
The first one i looked at, a review say it worked fine on a fiat 500
Here's another, a quick Google found
Yes you will have to wait a few weeks for it to arrive
Again I haven't used the supplier
CAN Bus Wiring Harness, for Fiat Doblo Punto Uno 500, Lancia Delta, ISO Cable Adapter, Plug and Play, for 16 Pin Car Android - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Yes
a cheaper harness adaptor but you will have to splice into a ignition switched wire and feed that into to radio so the head unit can detect when the ignion is on or off, to make it work with the ignition switch
a more expensive harness with some electronic gizmo are plug and play it receives the network messages (canbus) and converts them to something a standard radio can use to know when to switch it on and off
Yes
I’ve got a really really good deal on a unit that comes with this connectorJust to double check — is it this part (circled in red) I need in order to make sure the head unit turns off with the car?
YesJust to double check — is it this part (circled in red) I need in order to make sure the head unit turns off with the car?
Yes
If you want plug and play
It all just pushes together and works
No need to alter or add any wiring
Yes
It will not auto switch on and off with the ignition keyAnd if I don’t have this piece, will the head unit drain power from the battery if the ignition is off?
