Hiya, my fiat grande Punto 2007 make, 70k is making rattling noise for a while. Comes from somewhere at front.
Noise (attached) is only there when car is moving (no noise when engine is idling). It gets slightly louder /more frequent rattle when car accelerates, but the noise is still clear when going downhill (with no gas). It goes away when I press the clutch all the way down. Went to 2 garages, one said it's the gearbox (said clutch is fine) and other said its a broken flywheel (perhaps) and gears seem fine. First garage took it up to ramp to check.
Problem is both gears and clutch seem fine to when I use them ( no noise or problem when changing gears or pressing clutch down). Only thing is I've never changed gear oil ever, but both garages said it's pointless to change gear oil.
Any advice please, what can be causing the noise?
I understand Gearbox repair is pretty expensive (1k) especially compared to value of car. So if it is the gearbox, it might not be worth getting if fixed. Any help or advice to understand the noise will be much appreciated.
