CipVolt
Hi, guys
I've converted my Fiat Ducato 3.0 comfort-matic Bluebird minibus 2012 into a 6 seater campervan. After I re-build the engine and done lots of other problems, the bus was running fine for 15 min but when I comeback later after 2 weeks, the gearbox couldn't shift into Neutral position. The shifter can be moved mechanically speaking but on the dashboard it is still showing as on 1st gear! Because of this, when you turn the key into ignition, won't do anything
A local garage checked the fuses and other wires but it seems to working fine.
What are the possible issues here and how to remove manually the shifter into neutral as I need to move the vehicle asap, pls?!
I can only hope that someone had the same issue and could share this with me/us!
