Interesting. I always have 1/2-3/4 tank level od petrol, that is cca 30-40 litres. Every month i put cca 10 litres of fresh 100 octane petrol.
Hi
I know I'm writing in an old thread, but I didn't saw a solution for the problem and ... here I am
I had absolutely the same problem with Fiat Bravo MK2 1,4 with LPG
The first start of the engine was awful (the car started after 3-9 retries ... )
A few days ago I finally found a solution - to delete the adaptations on the ECU
According to the worker in the service shop, if the adaptation is more than 20% far from the genuine value, the ECU cannot revert the adaptation by itself, and the problem persists until the adaptation is deleted.
In my case, after the adaptation was deleted, I drove 200 km on gasoline to allow the ECU to make a proper adaptation. After this, the car is starting without any issue (like a new car)
The last step is to make new settings on the LPG system (because the old settings were based in the bad adaptation) - this was also recommended by the worker in the service shop.
That meas your LPG system was improperly calibrated.
On my car the adaptive parameters always stay +/-3% (5% up to 5% is acceptable) .
Still have the cold start problem with petrol that sits too long in the tank.
After i consume that, and add new petrol. there is no problem.
Hi
Sorry, maybe its a silly question, but who can delete those adaptations: someone with a Fiat interface or the guys that installed the LPG on the car. I have the same problem with a Bravo 1.4 90hp with LPG.
why do all normal cars fill up 95, and I have to fill up 98 in this **** ?Try to refuel with high octane fuel. more than 98. i fix the problem with this. no issue for 4 years
Where are the filters located and where can you order them?
Зареждам бензин над средата и пали сравнително добреAny updates on the topic?
is this a permanent solution?I put gas above the middle and it fires reasonably well
Thats how i use it, if the fuel tank goes under half full, the car takes around 5 minutes to start every morning.is this a permanent solution?
