Technical Fiat 500x 2015 check engine light, drive mode unavailable, stop/start unavailable
Meganrose
Darlington
Hi all,
My 2015 fiat 500x check engine light came on a couple of weeks ago, struggles to start a little bit and judders when standing still, but after 15 minutes or so of driving it’s absolutely fine. Check engine light remains on though.
It comes up saying drive mode unavailable and stop/start unavailable.
After a few days this went off and all issues were gone! But then after about 2 weeks it has came on again, same issues.
I took it for diagnostics and they’ve said nothing had came up, battery is at 70% so they can’t see what the issue is, and that I should take it to the main dealer.
I wondered if anyone else had this same issue and I don’t fancy taking it to a main dealer to pay a fortune when I don’t have to!
Mileage
63500
Hello,
It’s at 70% charge, I have had a look about since and have found that if your battery is at 70% or less it’s about time for a new one as it’s common for stop/start etc to stop working as a result of this.
The gearbox is 6 gears, and it’s a 1.6L diesel
No idea if the 500x main earth strap is the same as in the 500, if so, that could be the problem.
In the 500 it's located under the battery. Cleaning the battery terminals and checking all over the earth cables / ground is also a job to do on a 10 years old FIAT.
As for the battery, before buying a new one, I'd go to a battery shop to check the one on the car with a LOAD tester (not the fancy electronic one).
Hi all,
Got the same issue..car all working fine but noticed the temp gauge reading 54° so will be changing the ambient temp sensor..has anyone got a video or method of changing this?
