General Fiat 500 usb and 3.5 aux jack fuse
tony7777
Hi my usb and the aux jack is not working any one know the fuse and were it is the radio works ok
Hello,
I don't think these are protected by a fuse. The jack has almost no voltage at all, the standard USB is only 5V. And I'm not sure if those power pins are connected in the car.
Perhaps this function can be disabled / enabled in the radio menu? Or MES?
OK thanks
The USB is intended to use with USB sticks I suppose, so it should have the 5V pins connected.
If you have a multimeter, you can carefully see if there's voltage on the external 2 pins inside the USB socket:
That could give us a hint.
