G gsc1ugs Member Joined May 6, 2005 Messages 126 Points 79 Wednesday at 8:13 AM #1 I have a ford ka 2010 68k miles just stopped, its a fiat 500 engine hence why on this forum, has anyone any clues what to check? Dtc’s below Attachments IMG_6588.jpeg 2 MB · Views: 32 IMG_6587.jpeg 2.3 MB · Views: 24
C chris3234 Tipo owner Written a guide Joined Oct 22, 2017 Messages 5,017 Points 1,177 Location West Yorkshire Wednesday at 8:59 AM #2 Battery or main engine earth cables would be the first 2 things I'd check before looking deeper
OP OP G gsc1ugs Member Joined May 6, 2005 Messages 126 Points 79 Wednesday at 11:19 AM #3 New battery Where is main earth strap pls? Engine turns over no spark
John202020 Never straight forward? Parked in the garage Written a guide Joined Feb 5, 2016 Messages 6,760 Points 1,557 Location Tynemouth Wednesday at 8:07 PM #4 When was the cam belt last replaced? Could be a simple sensor, fuel or spark
OP OP G gsc1ugs Member Joined May 6, 2005 Messages 126 Points 79 Thursday at 7:06 AM #5 John202020 said: When was the cam belt last replaced? Could be a simple sensor, fuel or spark Click to expand... Its chain, there is no spark
GettinBetter Fundamental Sigma Parked in the garage Written a review Joined Oct 18, 2023 Messages 660 Points 279 Location Folkestone, Kent Thursday at 7:43 AM #6 Question about 'No Spark'. Is the coil block an intelligent device? I have noticed two pins in mine when cleaning plugs, but one could be power (with ground going through casing via mounting bolts) and the other could be high speed CANBUS. Anyone know?
OP OP G gsc1ugs Member Joined May 6, 2005 Messages 126 Points 79 Thursday at 9:05 AM #7 I tested pin 1 with multi meter get 53 across the 4
A3jeroen Prominent member Parked in the garage Joined Sep 23, 2007 Messages 2,938 Points 752 Location Alkmaar, Netherlands Thursday at 3:59 PM #8 Cranksensor? Does the rev counter move while cranking? gr J
OP OP G gsc1ugs Member Joined May 6, 2005 Messages 126 Points 79 Friday at 7:07 AM #9 Will check Can it be checked with multimeter?
C chris3234 Tipo owner Written a guide Joined Oct 22, 2017 Messages 5,017 Points 1,177 Location West Yorkshire Yesterday at 6:19 PM #10 gsc1ugs said: Its chain, there is no spark Click to expand... Chain? Is it a diesel engine?
OP OP G gsc1ugs Member Joined May 6, 2005 Messages 126 Points 79 Yesterday at 6:47 PM #11 No petrol may not be chain
John202020 Never straight forward? Parked in the garage Written a guide Joined Feb 5, 2016 Messages 6,760 Points 1,557 Location Tynemouth Yesterday at 8:22 PM #12 If it's the 1.2 Fiat engine then it's a belt, think even the 1.4 is a belt, as far as I know only the diesel is a chain
