Help please, 2014 Panda 4x4 1.3 multi jet diesel engine problems. Has always had main dealer service so correct oils/parts used. Noticed that it had become sluggish and tiring to drive, also gears were stiff. Car still looks nearly new inside and out. Last June suddenly failed to start, got picked up and taken to garage 45mins away. Diagnosed worn timing chain, this was replaced and gear change was sorted. Whole job took ages. Collected car and it was in limp mode. Took it back and another 3 months went by. Went to investigate and found garage closed down. Subsequently spent money on correcting bad workmanship but there remained misfire and smoke. Have just found out that the injectors were wrong ones for the car and also not a matching set. Car has failed compression test. My question is this: is 150k miles considered end of life for these engines? Anyone know of a reliable source for reconditioned engine? I'm based in Norwich. Be grateful for your thoughts/advice.
- Model
- Fiat Panda 4x4, 2014, 1.3 multijet
- Year
- 2014
- Mileage
- 150000
