Hi, I've been searching for a solution to a problem with my car going into limp mode and showing multiple error codes.
The issue is that under engine load in 4th, 5th, or 6th gear, there's a sudden drop in power, and it triggers a boost-related error (P0237-61, P0238-61, P0234-62, and probably some others that I haven’t had a chance to note down). After clearing the error and restarting the engine, everything returns to normal, and as long as the engine isn’t too heavily loaded, the error doesn’t appear.
I've already checked the Pierburg valve, boost pressure sensor, airflow meter, and intake tightness, and everything seems fine. Recently, I took some logs in MES, and one thing caught my attention – the relationship between the expected and actual turbo position. Specifically, the actual position never exceeds around 3.700 mm.
Could this indicate a stuck variable geometry? Or could it require adjustment?
