Technical Ducato scuttle cover seal
pwish
York
Hi everybody, I have a 2017 ducato based motorhome and noticed water dripping from the coolant reservoir access cover seal . I removed it from the scuttle panel and discovered the seal to be damaged in a couple of areas . The seal appears to be bonded to the scuttle , does anyone know if it can be replaced or recommend a suitable repair .
Many thanks
The cheapest most effective way I found was to use 3M electricians tape over the seal on the scuttle panel and windscreen. I cleaned both surfaces with IPA and then added the tape. I just replace the tape every years and it keeps the water from entering the engine bay between the windscreen and the worn warped scuttle. I bought the tape from Screwfix for about £3.
So 'Scuttlegate' is still happening !. This has been a long standing problem with Ducato's since the X250 first started in 2006/7
Part of the problem could be broken mounting clips when the scuttle was fitted, or a warped scuttle. Either way water can get into the engine compartment between the windscreen and scuttle and at best leave puddles in the area between the cams, or at worst get into the electrics.
I have a 2007 Ducato which had a scuttle you could put your fingers behind when new. FIAT not interested, there solution, spray 'Waxoyl' onto the top of the engine, so did a 'fix' myself.
Firstly you need at least a day (preferably two) to do the job, and again preferably under cover if possible, or choose a couple of dry warm days.
Process is:
1, Remove bonnet. Not too difficult, four bolts but heavy so might need two people to avoid damage to yourself or the van
2. Remove both wiper arms having remembered to leave them in the 'park' position.
3. Remove the scuttle. Not sure with the newer model but the 2007 was in two parts. From memory two screws near the middle, and two near the ends.
Now pull the scuttle outwards to disconnect from the mounting clips. Chances are either some missing, broken, or distorted. If any are, try to get replacements.
4. Give the bottom of the windscreen and scuttle a good clean.
5. Now the difficult bit. I used 'Sikaflex 521' because I had some, but other flexible sealer/adhesives will do. Preferably do not use Silicon type sealants as
they can be corrosive and will fail faster than Sikaflex type adhesives.
Make sure all clips are in place, then run a thick bead of sealant along the top (windscreen) side of the scuttle, basically on the back of the more flexible section.
Put the scuttle back and make sure the clips click into place and sealant oozes out of the top (windscreen side) of the scuttle. Keep pressure on the scuttle until the adhesive has dried. Sikaflex takes about 30 minutes but I used some bits of wood to leave it for a couple of hours to dry.
6. Once you are happy the adhesive has dried, cut of the excess from the top of the scuttle. Carefull you do not damage the windscreen.
7. Put the screws, windscreen wipers, bonnet back.
Scuttle should now be well sealed and not leak at all if it has been done correctly. As an add on, it might be worth fitting extra drain holes on either end of the scuttle as if parked on a sideways slope, water can overtop the scuttle and get past the scuttle/bonnet into th engine compartment. There was a kit on FleaBay for this, but I did it myself.
Pro's, Did the mod in 2009 and not had a drop of water come into the engine compartment since.
Con's, If you have to replace the windscreen it has to be done again.
Many thanks for your reply and advice
You can also use a thin rubber "p" strip under the scuttle plastics with sealer to help stop the water getting inside the engine compartment , 1/2 inch fittings drilled thro the scuttle with long pipes also get rid of the water , bit of trial and error to get it right , but worthwhile doing .
Did a little bit of FleaBay searching and found the scuttle drain mod kit similar to the one I fitted myself.
FleaBay item 265781120325
Only down side with this mod, if you live in an area with trees/bushes then the offside drain underneath the wiper arm will block up
on a fairly regular basis, but when not blocked does do the job well.
Does not fix the windscreen to scutlle leak though.
Process is:
Scuttlegate has been around since the evolution of the ducato, its expected to open an old ducato engine bay to be faced with a picture of doom
Just want to jump on here instead of making a new thread
The scuttle tray on the x290
The compartment that lifts out to fill coolant or power steering
Does anyone know what the black foam is called they use to seal the lid ? Mine is leaking in this area I’ve pulled it off and bought something similar I cut down but not done the job
Can you buy some sealant that sets like this black foam like a sponge
We have a 2017 RHD Ducato. The centre scuttle drain has a male to male joiner above the cam cover. I sealed the down stream side of the joiner into its pipe as water leaked here.
I still find water drips from the right windscreen wiper shaft on to the cam cover.
Many thanks
Hi, can I ask if you managed to get a fix for this please? I'm having the same issues and have temporarily taped the scuttle to the windscreen which has stopped most of the water but the cover that accesses the coolant is still leaking. Like yours it appears that the rubber seal has come away a bit.
Many thanks
