Technical Ducato issues
Elite130
Ireland
Hi 2016 ducato 2.3 130 multi, few issues with it, throwing code p0089 and traction control and going into limp mode, switch off and on and it clears and goes perfectly then same again.
Sometimes blowing extreme white/blue smoke randomly
Model
130 multijet 2.3
Year
2016
Mileage
130000
DucatoP0089Fuel Pressure (Regulator at High Pressure Pump Inlet)
Do a search here, there are a number of threads with this code. What is precise model eg is it euro 5,5+ or an early 6
The injectors are sometimes implicated in this type of problem.
Yes seen them alrite but no1 seems to of given a definite answer on what worked.. Don't know myself which model 2016 2.3 130 multijet non adbule, if injectors would it not be a constant problem cheers
injectors easy to spot
At idle fast rev engine to 2-3500 rpm a few times then allow to idle. give it a sec and watch exhaust. if it Smoking it most likely injectors.
