Hi, I have a 2019 Ducato Roller Team motorhome which has recently been serviced. On the way home it went into Limp mode with a amber engine check light up. I took it to a garage and fault codes are: P0401 - 61 (EGR high pressure valve blocked closed - signal calculation failure). Also P0402 - 61 (Air tracking control system). I am not sure of my exact Ducato model but the VIN number is ZFA25000002J6552. Engine type: F1AGL411D and engine number 3389301. The van is ex UK rental but now in New Zealand and I am not sure whether it is euro 5 or 6. It is not Adblu, so must be a 130 that was produced before Adblu. Any clues as to the exact model would be helpful thanks in chasing the EGR problem. I know it has 2 EGR valves (high pressure and Low pressure). The garage also said there was excessive build up of soot at the DPF. Don’t know how they saw this as I am pretty sure they haven’t taken it apart. Any clues would be appreciated, thanks
