Further update, replaced the fuel filter, freshly charged battery and another non start event, no codes or EML showing. I already had the cover off from the floor panel between the seats, no sound of fuel pump priming, I can hear the relay clicking on and then off again after about 10 sec or so. Put a multi-meter on the pump connections at the fuel tank lid and this confirms that 12v is coming on with ignition on and then going off about 10 sec later, as would be expected. So I think this now confirms that the fuel pump is dead/dying, I ordered a new one a couple of days ago and it should be arriving Thurs or Fri.
Charlie 58 - The code only appeared after the Spanish mechanic had been cranking the engine a long time with additional booster cables and also using easy-start, which made the engine run for perhaps 20 -30 sec. The rev counter needle does move when cranking and my bluetooth reader shows 200rpm when trying. When in Spain we did replace the crank sensor, the original was a Bosch the replacement is a Meat and Doria, as it now appears this wasn't the issue do you think I should put the Bosch back on or just keep hold of it as a spare? The original earth strap was replaced about 7 years ago and checking it in the last few days it still looks in good condition, although the connection bolts now look a bit tarnished.
Out of interest at what mileage did you have to replace the timing chains?
Cheers Phil
Cheers Phil
