We are moving towards having to hold the footbrake, so lights always on. Electric vehicles require it when stopping temporarily, some do not have a manual parking brake, and I cannot see owners pushign the P button, then selecting D again to move away.
In fairness...if they set up hill holders to release when you press the accelerator rather than after X seconds that would be solved.
The one in ours you must press the brake firmly after stopping to activate (assume it holds whatever pressure you had in the rear brakes as if you gently roll to a halt you will go backwards once the momentum has gone). In theory that would be fine if it wasn't on a 2 second timer so you must sit on the pedal until it's time to move.
As a result decorative in most situations...I just use the (manual) handbrake which then means no assistance from hill holder as no pressure in rear brakes. But if the 2 second timer wasn't there you could easily use it in lieu of a handbrake. Only useful as is for uphill "peep and creep" and obscured junctions when you spot something coming.
