Mattdada New member Joined Sep 21, 2013 Messages 18 Points 6 Sep 21, 2013 #1 My driver side window gets stuck when going back up in 3 stages. Have to hold on with switch & pull with hand to get it to go back up. Window will go down with no problems. Can anyone help
Fiatpuntomk2b Patron member Parked in the garage Joined Sep 28, 2009 Messages 2,858 Points 647 Location West Midlands Sep 21, 2013 #2 when the window goes up , does it pop out of the rubber ?
OP OP Mattdada New member Joined Sep 21, 2013 Messages 18 Points 6 Sep 25, 2013 #3 No it does not pop out of the rubber. Just gets stuck in 3 stages & makes a horrible noise.
A atom0007 Patron member Written a guide Joined Sep 7, 2010 Messages 2,388 Points 468 Sep 26, 2013 #4 I would guess contamination/failure of the mechanism, or stuff wedged into its guides. Are there long vertical marks on the window?
OP OP Mattdada New member Joined Sep 21, 2013 Messages 18 Points 6 Sep 26, 2013 #5 No long vertical marks at all.
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 36,294 Points 8,215 Location Near the M4 Sep 26, 2013 #6 Hi Matt, ask this in the Punto 2/ b section, I think it's motor drive fault, but they may well have come a cross it before, charlie
Ziggy122 Patron member Parked in the garage Written 10+ guides Joined Apr 8, 2008 Messages 16,742 Points 3,187 Sep 27, 2013 #7 Puntoa arent known for there window faults There pretty fahltless tbh.... My advice is pop the door card off and watch the mechanism Make sure it pushs straight Clean and regrease ths tracks is always a good idea as well Ziggy
