Sounds like the infamous D4 connector has been giving you problems.....
This makes a lot of senseNumanR said:D4 is the connection block in the battery housing, it is the main link for light wiring to the engine. It has several important wires which run through it, including CAN lines, throttle potentiometer signals, etc, etc. It is one of the most demanding connector blocks in that it is susceptible to alot of vibration, heat and cold, and if the engine bay gets steam cleaned with the battery cover off it can trap water inside it. All DETs know this connector and its regularly checked for any signs of problems during diagnosis procedures.
PNL said:The D4 conecter is behind the battery take of the cover and you will see a largish block about 9cm x 4cm this has a lift up lever on the top when you pull this lever up a piece in the front will push out after that who knows cos i havnt been able to get the damn thing to seperate so if you do POST IT HERE![]()
T14086 said:Please send a blank cheque to T14086,locker 075,glasgow train station![]()
:chin:
Well look who's hiding away under the fusebox
Could it be?
