IT is posible the lamda 1 senzor to do this problem ,
poor mixture ?
poor mixture ?
I have a 1.2 litre POP.
Twice, when it hasn't been driven for a week and the second time not driven for 24 hours, it has not started without a lot of cranking. The engine turned over fine.
The first time this happened I gave up on the starter motor and roll started down a hill and it still took a while to fire up. I drove for five minutes fine, stopped for dinner nearby, then again it wouldn't start without maybe six attempts, a friend says it blew a bit of smoke on starting.
Then 10 days (900km) later it wouldn't start again, I cranked it about 15 times, it spluttered a bit a few times and then fired up and went fine.
I thought it might be dodgy fuel, water in the fuel, or fuel evaporating somewhere.
It has happened on hot days when the car has been sitting in the sun.
One possibility is a slightly leaking injector. The fuel rail doesn't automatically depressurise on shutdown, so if one (or more) of the injectors isn't completely closed, fuel could leak into the cylinder, causing a wet, smoky start.
the car start fine always when u ,,spray at the top of map sensor with frezz spray,or brake cleaner !
The car need a feedback from the pin 2 ,temperatur manifold interior ! Sometime start with this pin cut of ,sometime not.
I try a circuit bord ho disconect this pin for 20 second ,but not workind.![]()
I have in my mind and i order a board ho do,, down power adjuster' .In map sensor enter a 5 v , and at pin 2 send about 2-3 V back to ecu, i will use this 2 boards ,one to disconect the original pin2 and conect to adjuster and after 1 min to conect the original pin .
Now the car starts ok after the custom i made again, but i will prepare if the problem come back !
I do a live test at pins of the ecu plug.
I know every wire from MAP sensor where did go in ecu plug.
The voltage depend of temperature, with MAP unplug is 5v standard, and with connected plug and engine coold is 3,33 V.
With the hot engine the voltage is 3.22 v.
But when i use the coold spray at senzor map and the voltage increase at 3,50-3,70 voltage the car start ok.
Hmm lambda,yes, but when u put the key on, the ecu read form some senzor Map and temp and do the mixt. The lambda read from exhaust, airflow.
If i dont find to remap the ecu, i tri a scam, a divice to lock the circuit of pin 2 about 1 min and than open.
hy , the value is about there !
I dont know whay about 1 year work okwith that map , and then reapear, somebody say the ecu made a refresh at setting/map.
Hello my friend,follow!
U say if u have half or more fuel tank start ok ? did u check the purge valve or vapor trap
You could contact a specialist who can read the live data when starting and see if there's an error in the fuel mapping ?Hello my friend,
I have same issue on 2008 Stilo 1.4 !
Changed:
- spark plugs (iridium)
- ignition coil
- battery
- fuel pump
- all fuel injectors and fuel rail
- starter motor
- alternator
- MAP sensor
Still persists. Regardless of weather, first start (after 5+ hours) always hard. Other start always immediately.
Any update on the issue from you? Have no idea what to change next
Of course I could, but before I do, I wanted to find out if these issues were resolved, since they are 99% the same.You could contact a specialist who can read the live data when starting and see if there's an error in the fuel mapping ?
Hi from CZHello my friend,
Changed:
- ignition coil
- battery
- fuel pump
- starter motor
- alternator
- MAP sensor
Thanks for the suggestion, I will try some 98 octane fuel tomorrow, maybe the issue is the "biosložka" in the 95 octane fuel in CZHi from CZ,
I have the Fiat 500 2008 1.4i 16v 74kw - problem: after sitting for more like 5 hours (cold engine) - first start is like shaky bad and usually goes off. The second start is usually fine, like nothing was bad before.
Changed:
- spark plugs (from bosh to original NGK)
- battery
- cleaned fuel system several times
- MAP
- filters
- timing belt (Fiat specialist did it, so should be fine)
- oil change with engine flush
Nothing helped. What helps: Switch from 95 octane to 98 octane.
With ONO (you will know from CZ) or other "cheap" 98 octane car runs just fine, every start from full tank to empty is fine.
100 octane (Verva/OMV/...) --> doesn't work, same problem
- also works - 1/2 tank cheap 95 and 1/2 Shell Vpower 100
- VIF aditiv doesn't work only with 95
- now I bought Millers oils petrol power ecomax - should add about 2 octane number to cheap 95 and I will test it.
I was asking for some ECU tuning/update, nobody in CZ was able to answer. Some cars here (same ae and engine specs) works fine, some has the same problem.
I also asked mechanic, if intermittent cold start could be problem for car (catalytic converter or lambdas, starte, idk...) but they said, it is only minor issue and it should not harm anything.
Also, mechanic said, that some 1.4 T-jet have issues with gas quality, so... seems legit.
Only problem is, that for example 100 octane is easier to find, and 95 is much cheaper, so I hope some kind of additive will help us, so we will be "free" to visit any gas station we find. In other case I will buy some 98 from ONO to jerrycans and I will pour it into 500 at home![]()
