Watchman077
- Joined
- Jul 8, 2021
- Messages
- 2
- Points
- 2
I have recently bought a new Carado Camper Van based on a 140 bhp Ducato Panorama with an auto-gear box and stop start. We took it to the nearest Fiat dealers for them to sort out a few minor niggles and no stop/start. The technician said the battery was only 45% charged & the top start will only work once the battery is above 85% charge. I told him we don't use the van regularly.
He said that if I wanted to charge the battery, open the bonnet & connect the negative charger clip to the earth terminal thread in the centre and the positive clip to the a terminal under a black plastic hinged unit on the RHS.
I bought a charger and read the manual - that tells me to disconnect the negative battery terminal and a sensor for the stop start before charging.
You Tube videos also show the battery being accessed under the cab floor and the the earth terminal being removed first.
Also that the terminals under the bonnet are just for jump starting.
Any ideas?
Any ideas?
