Technical Charging Bateries
Fithawk
Bristol
With the Leisure Battery on hook up charging, does the Cab Battery charge at the same time?
Rimor Horrus 66.
Model
Rimor Horrus 66
Year
2024
Mileage
3500
Rimor Horrus 66.
Hi, that entirely depends on the system Rimor install.
The EBL system does on Hymer’s, not sure on Rimor and can’t find any specs for the charger to have a look.
An easy way would be to put a multimeter across the starter battery while on hookup. If it’s above 13.5ish volts after ignition being left off for a few hours, then it is charging. An alternative would be a cheap cigarette plug that shows volts off eBay if you don’t have a multimeter.
If it doesn’t charge, you can install a battery master or similar to give it some charge and keep it in good condition. About £70 to buy and very easy to fit.
Thread below explains these.
Many thanks for the info, I’ve decided to go the 12v outlet plug in route. Thanks again.
