Hi There, I impulse bought a motorhome with a 1996 2.5TD 5 speed manual gearbox KM20KM. I now find I may have gearbox problems and after looking on this site I see this 5 speed gearbox is a bit notorious for 2nd and 5th gear issues. I may be lucky and have overfilled it with oil and it seems to be running ok. BUT when speaking to recon places all over the UK the general message was that due to the issues these gearboxes are getting rarer and rarer to source - or stupidly expensive. I was also told that you can't mate any other gearboxes onto engine if its the 5 speed manual diesel. Is this true? will any other 20KM versions that would work?
Therefore, and this is the key bit I wonder if anyone can advise on.......... Is it possible to take a later 6 speed 2.8TDi engine or just TD engine and fit it into the 1996 Ducato chassis? Does it fit? are driveshafts too different? Anyone done this? is it a straight fit or too complicated? Are there any known alternatives? Am very concerned if gearbox goes bang at a later time I will be stuck with a stationary expensive wendy House! Aaaarrggh! Help! Cheers
