Seicento Chalky, 1.4 16v ITB Seicento.
I don't know if you guys remember but back in january I was starting a project that involved me swapping the piston rods from 8v ones to the 16v ones, fitting a 1.4 8v grande inlet manifold, and a spicy CB cam :D.
Well that got thrown out, and I promised you I would still do a project.
I Delivered:
The donor engine was removed from a 2003 fiat stilo 1.2 16v with only 28k on the clock.
I got the engine home, stripped it down and painted it pretty much straight away (getting quite high in the garage during the winter :D).
Re-assembled with pistons soaking on oil for the next several months.
The next thing that was on the "to-do" list was chassis tweeks and upgrades.
So off came all the brake lines (They were definately on their way out, so it should be on everyones checklist. Please I do advise this), radius arms, rear beam, petrol tank, handbrake cable, wishbones, front uprights, front calipers. I took everything off so that it was just a shell with windows, steering wheel and seats.
Brakelines were all replaced with 3/16 cooper nickel and shiny stainless fittings, finished off with some nice goodridge braided lines.
Rear beam was tidied up, painted and refitted for the new lines to be correctly routed.
Whilst I was doing the brake lines the radius arms were also being tidied up and painted, along with anti roll bar, uprights, and my front upper strut brace.
Then came a nice delivery of my marea rear calipers to go with my PGT front, they got stripped down and wirebrushed right back to the shiny stuff :D. (see the before and after)
Then got a lick of paint again.
A little while went by then a nice postman came again with my fresh polski produce
A few days later another box came from good ole gazzella.
Then my mount plates arrived from Signwerx so I finally got arond to refitting all my back end.
Trial fitted my wheel with the 10mm spacers from the front, Discovred that i'm in need of 15mm at the back due to rubbing on the radius arm :bang:.
And same day I got bored and re-fitted the front too. All finished off by my custom Gaz coilovers on the front, and custom Gaz dampers on the rear (Need a coil chopping out on the rear mind just so the car is nice and level).
The bushes were noticeably stiffer even off the floor, no give or flex in the material at all. I theory with some decent tyres this car should stick to the floor nicely (y).
nother payday was coming up so the head got some attention in the form of a dremel, dividers were thinnned down, ridges ground out, drill marks were ground out and smoothed, and to finish off. Hand sanded all off it smooth with good ole 80 grit for the inlet, and outlet was smoothed out finer and spent a few hours polishing till bling bling :cool:.
Valve hole on the right shows what it was before grinding, left shows part way through grinding.
Never got any photo's from that night of finishing it off but It will improve flow no end (I hope :rolleyes:).
Next day it went to my local machine shop to have a couple of new guides fitted, skim, and reseat with new seals.
Inlet:
Exhaust:
A trip to another fairly local machine shop resulted in:
1.8KG taken off the stilo flywheel, balanced with the clutch (happy days :D)
Got home that night and decided to make a hesitant start on re-fitting the head :cry:.
I've never poo'ed myself so much tightening bolts up.
Was all fitted without so much as a sqeak (followed adived and gently wiped engine oil on the bolts).
So happy after that I then fitted my manifold and oil filter.
Then began painting my head and fitted it next day along with water pump pipe from the old engine (new seal, again advise checking quite oftenly).
Timed up and ready to go in :D
Then postman came again (y). Hello drilled and grooved.
That Weekend came, so did my friends brother (whom I owe a drink (y)) and something magical happened in a few hours.
We did manage to break my new crank sensor in the process mind :bang:.
Sexy ;)
Then I struggled a little for and inlet manifold but then I managed to source one from a fiat breaker then along came Kritip to help me with the wiring (thanks again bud (y)). Spent the last few days finishing that off and last night it fired up for the first time in 5 months.
Made some awesome bangs before hand though due to us having the coils wired backwards (oops), quick swap of the leads and it fired up first time (y).
All that is left to do now is get myself a set of new tyres, get over to custom chrome in the morn and get my new front exhaust section made (yes we started the car up without and exhaust, sounded nice and loud :tempt:) Cov69, and kritip both were witnesses to the start up :D. Thanks again guys for your help.
Ohh before I forget, here some pic's of the new wiring for the battery, starter, and alternator:
Hint, it's the big thick one without the fuse on it :D.
Here's where i'm up to, i'll update this soon :D.
Re: Chalky, The 1.2 16v Sei
6.5? They're from 1985!
I still have that set of 6.5*14 (ET30 iirc) Compos in the garage to go on my Cinq at some point, be interesting to see how you get on with getting these onto a Sei with the (apparently) narrower arches, and also how much to get them reconditioned (one of mine needs a little straightening... or rounding :) plus new paint/power coating).
btw I did a bit of research for mine and found some pics of 195/45 on 6.5*14, the tyres do look a little rounded but it's hardly a stretch, if anything it might *just* help to tuck them into the arches.
http://polo-land.fr/forum/ftopic5889-0.php
If the logo is under the surface of the cap, not on top, could you sand/polish a thin layer off to renew them? Kinda like how the scratch 'removal' kits for CDs/DVDs/games work. Unless you mean the clips around the back are knackered too.
The original mesarati caps have an metal plate with the logo on and that has corroded and been damaged on all of them (one is missing :bang:) (n).
New set of caps on the bay is going to set me back £50 plus import fee's.
Maserati forums are my friends right about now (y).
X
Felt an update was needed.
Trial fitted my maserati wheels, no rub at all on the inside due to the ET being 8, which means I don't even need spacers.
Downside is they stick.... a bit....
On a plus side they do look very sexy, and i'm definately going to be fitting them.
X
I can't wait either but I need to get my front lower strut brace sorted for these. Need to make one that sits about an inch higher up.
Anyway I forgot to mention, the tyres taken off weren't 8 years old. They were 26 years old :D.
That car must of been garaged all of it's life.
X
dude pics of the new brace disign when you do it. something ive been pondering for a while. also nice wheels. not my cup of tea but suit your car great! good choice. camber them and stretch???
I'm going to be using camber bolts as I need to get rid of that positive camber that chalky seems to have.
I don't really want to stretch on these wheels but they are my whores, and debating keeping the BK's for my track wheels.
We will see what I want to do when it comes they are refurbed and i'm happy (y).
For now I just need to get my secret ninja project out of the way :devil:.
Which has just gone from stage 2, to stage 2 and 3 (hopefully).
X
No spacers needed, ET of the wheels is 8. Standard ET of the seicento is 27 (ish).
I have full clearance on the inside of the wheels, just going to have some rub on the outer arches once rubbered up.
May have to get the arches rolled at some point, which means I need to get busy making some fiberglass inner arch liners :bang:.
X
Yea :D.
The pics make them look like they are sticking out more than they actually are, slightly exaggerated angle but then it was hard to get a stright down shot.
Either way as soon as they are refurbed I can get them on properly and get the suspension settled then they shouldn't stick out as much, camber bolts should sort some of it out aswell.
Might test the back out, just to see how much arch work will be needed there.
X
Taken some more pictures today so I thought I would share my work.
Still not telling the secret ninja work, maybe i'll spill next week :D.
Still some of that seam sealer crap in there but can't be bothered to remove that just yet.
I was tempted to weigh all the removed material but after driving it has made quite a noticeable difference not only noise but the way to car feels.
X
