General car radio aerial replacement
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
hadalad
Some low life snapped my aerial last night, leaving the threads from the aerial snapped off in the base so now I need to replace both the base and aerial.... the trouble is how do I remove this......
so I can remove this......
I take it I need to remove the interior trim to get under the roof lining so I can remove the nut on the base ??
hiya, they're a bit of a pig but I did mine with a small drill and a bolt shifter.
The inner part of mine was brass, so I drilled a 2.5mm hole in the centre, using a #1 left handed bolt shifter, GENTLY drive it into the broken bit of the aerial stub.
you might need a little heat, I've found it helps. Be careful of the plastic round the base, and of course your roof paint. If you have a heat gun, it's a bit more gentle than open heat.
Hope this helps
George
Thanks for the replies fellas, ordered a replacement one from e bay, bad mistake as it was totally the wrong base.
Tried an easy out tool but failed! so in the end I have soldered a long bit of insulated wire onto what is left of the antenna base and it works a treat but looks ugly, that said it fits in well with the rest of the car LOL
cheers.
